• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Updating Specs retro activly
    132 Views, 3 Replies
    09-26-2012 11:04 AM
    I have a nearly completed project and I need to modify the specifications for a specific class of fittings. After editing the catalogue and specs how can I update the out dated refferenced specs?
    Thank you,
    Henry
    Please use plain text.
    Valued Mentor
    JohnHolder
    Re: Updating Specs retro activly
    09-26-2012 03:12 PM in reply to: AnandHarrypersad
    an easy out would to be add the new spec under a different name, and use the new parts.  I have had to do this a couple times.  It does not work if you need to modify the old fittings in the drawing though.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Member
    09-27-2012 10:59 AM in reply to: JohnHolder
    Thanks, John.
    I guess I'll be modifying the existing parts as required. I was hoping to escape that.
    Valued Mentor
    JohnHolder
    09-27-2012 12:26 PM in reply to: AnandHarrypersad
    Unfortunatly that has been my experience.. hopefully someone else can give us both good news 8(
    Master Yoda.
