• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Unique TAG No.!!!!!!!!!! Please help
    166 Views, 5 Replies
    05-28-2012 03:34 AM
    I have had to delete existing drawings in a project and redraw but when I input the valve tag numbers it states please use a unique valve numer as the number is alread allocated in the project.   When I have a look in my data manager there is no record of these tags, I have noticed replies stating to edit the tag after it is placed but this results in a question mark appearing as the tag is a duplicate.
    Please help me as this is frustrating and holding my work load back when I have tight deadlines to meet
    thanks
    Andy
    Please use plain text.
    Valued Contributor
    andy.davis
    Re: Unique TAG No.!!!!!!!!!! Please help
    05-28-2012 07:33 AM in reply to: andyharvey84
    Hi Andy,
    Try running the Audit Project command from the Project Manager.  This should remove any unreferenced data from your project database and release the tags that you are trying to use.
    Andy
    Member
    05-28-2012 07:39 AM in reply to: andy.davis
    Thanks Andy
    I have tried this so many times and purged the drawing also with no result it is completly baffleing me.
    I believe others have had this problem and have had no sucess
    I have 18 very busy P&IDs with this issue with a tight deadline and there is no time for redraw.
    Cheers
    Andy
    Valued Contributor
    andy.davis
    05-28-2012 08:17 AM in reply to: andyharvey84
    How are you you 'deleting' your drawings ready to start again?  Are you removing them from the project and adding them again or are you selecting the contents of the drawings and erasing everything?
    One thing you could try as a last resort, is to create a new project using your current project as a template and then copy your existing drawings in to your new project?  Just a thought.
    Andy
    Member
    05-29-2012 01:48 AM in reply to: andy.davis
    The drawings are being copied from another project as the area is exactly the same so rather than redraw I am bringing in what I have created before but when I open the project manager every instrument turns to no target and all valves and equiptment turn to a standard symble with no properties. so I have deleted all valves and symbols and replacing them with new ones then it has the conflicting tag numbers.
    hope this makes sense
    cheers
    Andy
    Valued Contributor
    andy.davis
    05-29-2012 01:59 PM in reply to: andyharvey84
    If you are simply copying the drawings over the top of the originals using Windows Explorer then I suspect that you are confusing the project manager big time as none of the database references in the new file will be valid - hence the no target errors.
    You need to remove the drawings that you want to update from the project, then use the Copy Drawing to Project command in Project Manager to copy the 'new' drawings.  Alternatively, wblock out the contents of the 'new' drawings, erase the contents of the 'old' drawings and then insert and explode the wblock'ed drawings into the drawings you are updating.
    Andy
