• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    U-shaped tee's ISO
    251 Views, 4 Replies
    11-18-2012 08:04 PM
    Like this kind of componets in the picture.  The catologue and the iso skey are all custom by users.  And then when making ISOdraft the problem in the 1st picture occurred.
    In their projects, there are many components like this, for example, multiple-way vavle (as picture) also has the same problem.
    We has been nagged by this problem for a long time. Please help us to solve it.
    Thanks a million.
    Please use plain text.
    attila_vallyon
    Re: U-shaped tee's ISO
    11-19-2012 07:13 AM in reply to: kunbe
    I have the same problem with the isogen. I use P3D 2013.
    The isogen can not handle well the multiple port valves properly (more than two ports) unless the ports point against eachother in a valve.
    If the port centerlines does not come together in one point, the iso generator will not put properly the symbol.
    You can see the iso centerline when you select in the 3D model a component. And the centerlines do not intersect eachother in the valve.
    Unfortunately I do not know the solution for that problem.
    I think it is a isogen issue and has to be developed in the future.
    Attila Vallyon
    Valued Mentor
    Rich.O.3d
    11-19-2012 02:41 PM in reply to: attila_vallyon
    the valves in plant are 'inline' components, what you have in your model, I would call a piece of equipment, not a valve
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Employee
    TomislavGolubovic
    11-19-2012 03:56 PM in reply to: kunbe
    Depends on whats shown on the P&ID
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Member
    11-27-2012 06:45 PM in reply to: Rich.O.3d
    So, what about U-shape tee? Could it be equipment?  And how to define  this kind of vavle align, if they aren't "inline".
