• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Trying to access "properties" palette, ACAD Plant says its "unknown command"
    181 Views, 1 Replies
    11-16-2012 11:09 AM
    When I try to use the "properties" palette, ACAD Plant says its "unknown command".  It also says this for the qui kcalculator, design center, quick properties.  I go and modify my cui/workspace setup and save it after I know it looks correct.  Then the next time I restart ACAD Plant, the same palettes are off, and I have to do the same thing all over again.
    Does anyone know what the problem may be?
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: Trying to access "properties" palette, ACAD Plant says its "u
    11-19-2012 02:26 PM in reply to: dmitzel2003
    have your tried doing a repair on plant3d from control panel/programs
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
