• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    This annoying...line number
    260 Views, 4 Replies
    03-28-2012 06:31 AM
    i have a set of P&ID's that already have all the line numbers assigned. the client wants a different style of line number format. no problem, i edit the pipeline tag to generate the desired fields and start changing the line numbers on the P&ID's.
    for whatever reason about 1 in 10 line numbers keep reverting back to the old line number. i keep re-assigning the new line number and it still reverts back?????
    Please use plain text.
    Product Support
    jason.drew
    Re: This annoying...line number
    03-29-2012 02:23 PM in reply to: thebearjed
    When you assign the tag again, does the "Tag Format:" listed up near the top of the Assign Tag window match up to the new one in project setup?
    Jason Drew
    Support Specialist
    Product Support
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Roxana-Elena
    03-30-2012 02:38 AM in reply to: thebearjed
    in the Project Setup/Lines/Pipe Line Segments (or Pipeline Group) and Properties: TagFormat/Dafault Value: "X" same as the one createed by you. Same for Annotation: you coose same block as the one desired to be shown on your drawing (next to Tag format)
    I believe Jason.Drew recomended same
    Roxana
    03-30-2012 06:10 AM in reply to: Roxana-Elena
    no, it does not match the one in project setup?
    Roxana-Elena
    03-30-2012 06:42 AM in reply to: thebearjed
    just match them and this should solve your problem.
    Roxana
