• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Tap Port (hole in blind flange)
    421 Views, 4 Replies
    04-24-2012 11:14 AM
    Does anyone know how to do a "tap port" on a blind flange?  What that means is drilling a hole in a blind flange and threading it to bleed a line.  I know in bentley it was possible, I am not sure if it is possible in CAD Plant 3D, an help/advice is appreciated!!
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Tap Port (hole in blind flange)
    04-24-2012 09:56 PM in reply to: jeremylegleu
    It's possible in Plant3D 2013.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    05-04-2012 08:08 AM in reply to: TomislavGolubovic
    Ok, we are using 2012 here.  Thank you for your response!
    New Member
    02-08-2013 12:58 PM in reply to: jeremylegleu
    How do you do this in Plant2013?
    Distinguished Contributor
    Arun_Kumar_K
    02-16-2013 03:22 AM in reply to: mtchad
    Set some size below than the main size, then tap the line from blind flange
