AutoCAD Plant 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Subtypes for valves in 3D
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
149 Views, 1 Replies
03-07-2011 04:39 AM
In our company we have 10 different valve types (check valve, ball valve, safety valve…). Each valve type has in average 25 sub types with same pressure and facing. If I place a valve in Plant 3D I have to choice the valve in a list of 250 entries. When i like to replace it I get also a list about 250 different valves in the context menu. Is there a possibility to create subtypes for valves in Plant 3D? For example: If I like to replace a check valve I would only see valves of type check valve?
Re: Subtypes for valves in 3D
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-07-2011 09:01 AM in reply to:
gfunke
From the sounds of it, you are using the default spec that comes with Plant3D?
You can make your own spec for the particular project with only items that belong in the spec for that project/client.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
