• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Student Version Problems w/AutoCAD Plant 3D 2013
    779 Views, 16 Replies
    06-30-2012 01:20 PM
    There is a problem with the Student Version of Plant 3D 2013.  The program will throw an exception error with the following message.
    When creating a new P&ID file.
    Unhandled exception has occurred in a component in your application.  If you click Continue, the application will ignore this error and attempt to continue.
    Filer error
    When entering Project Setup
    Error Decrypting Data
    I saw an question in Ask The Expert for Lori Wu on 6/19/2012 that this problem has been identified and Autodesk is working on it; however, I have seen messages for this problem since 3/2012.
    How can we find out the status of this problem and if a fix has been identified?
    Thanks.
    Please use plain text.
    New Member
    Re: Student Version Problems w/AutoCAD Plant 3D 2013
    07-12-2012 06:04 AM in reply to: marbtrjmr
    Bump. It's still an issue.
    New Member
    09-05-2012 10:19 AM in reply to: marbtrjmr
    I am having this problem not only on my home computer, but on 2 computers at school as well.  I have looked everywhere for a solution to this problem with no success, and have even called Autodesk only to get denied of help because I am a student and not a registered user.  This program is completely unusable since you cant create a new drawing from any component in project manager.  Autodesk, please find a solution to this problem.
    Employee
    TomislavGolubovic
    09-05-2012 03:42 PM in reply to: copeck21
    Does this happen on new Projects, or just the Sample one already installed?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Member
    09-10-2012 09:29 AM in reply to: TomislavGolubovic
    Hi!
    I get the same problem every time when I am opening the program.
    Attached the error.
    I scanned whole computer, I installed on another one, tried version 32 also on a 64 still same error. Should I try a cracked version :smileyhappy:  to end all possibilities ? ( please read it as a joke :smileyhappy:) ).
    Now seriously is any fix for this ?
    New Member
    09-12-2012 04:05 AM in reply to: TomislavGolubovic
    It happens on any project. You cannot create any type of new drawing without getting the error. I'm using the trial version right now and it works perfectly.
    Member
    09-13-2012 04:45 AM in reply to: marbtrjmr
    OMG! this is a noob problem imho how can you release a program if is not working from the start......nooobs! really sad....for a company like Autodesk.
    Member
    09-13-2012 04:47 AM in reply to: enemykillerro
    BTW if i try to install the trial version the educational enter automatucaly .I unnistalled the educational one before.Any suggestion ?
    Member
    09-15-2012 06:18 AM in reply to: enemykillerro
     is so so so hard ? :smileyhappy:
    New Member
    04-03-2013 03:05 PM in reply to: TomislavGolubovic
    I am an instructor in Texas and all of my students are experiencing the same issue.  We are more than halfway through a semester, and the curriculum is tough without the ability to be able to work from home.  I experienced, personally with the student version, an exception after I opened my project and went to start a new drawing.  Any drawing, P&ID or Plant 3D.  So it isn't just the default project that is the issue.  Our projects work fine on campus, but not at home.  Please advise if there is a possible hot fix or any kind of solution.
    Donna
