• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    ybogdanov
    Stub-in orientation in ISO
    209 Views, 3 Replies
    04-16-2012 01:56 PM
     another comment. The program insert with incorrect orientation all stub-in connecions. It's happen when the stub-in it's not form part of the iso:
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Please use plain text.
    Valued Contributor
    Re: Stub-in orientation in ISO
    01-10-2013 05:01 AM in reply to: ybogdanov
    Did you resolve it?!....
    I have one day and a Half trying to find a answer at the moment, my solution is when generate ISO.dwg, rotate each one acad block "SplitMark" to right direction, from properties.
    If you have a better solution, please can you share it.?!.
    thanks.
    this is my messege with same problem
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Isometrics-Stub-In-split-Mark-acad-Block/td-p/3749842...
    Valued Contributor
    01-10-2013 08:15 AM in reply to: ybogdanov
    Hi Yuri again,
    Speaking about this problem, I replay you that my solution was rotate AcadBlock "SplitMark" from properties.
    But this solution create a wrong coordinates, so this solution is not good.
    Also I change weld node (Only Weld node) to each different pipe some times in manifold and some times in branch pipe, but it is still  not work.
    Sorry, any Idea?
    Thanks.
    Valued Mentor
    ybogdanov
    01-10-2013 12:19 PM in reply to: ybogdanov
    I don't find any solution in this moment.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
