AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Stub-end for lap flange
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having an issue placing a stub-end for a lap flange in my project drawings. I keep getting an error:
"Pipeing is unable to be connected.
Cant' create part record in the project database"
I'm using the standard, out-of-the-box stub-in for lap flange. I tried this on two separate projects and had the same error message.
Jason Drew
Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Re: Stub-end for lap flange
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
are there any backing rings available in your spec?
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Also have you done a Plant audit on the project, right click on the project in the project manager and you'll see the Audit command.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Jason. Were you able to resolve this issue? If so, can you share the solution?
Eileen
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As far as I can tell, the stub end forms part of the fastener for the lap flange and cannot be placed on its own just like a boltset or a gasket. The option to Insert in Model is disabled in the SpecViewer for me. Have you checked the endcodes and joint Settings?
Andy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jason,
stubends are fasteners. You insert the flange which then will insert the stubend (as well as gasket and bolts). However, this automatism depends on the proper setting of the joint settings in project setup. By default it should work.
Carsten
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It seems there was something wrong with my test project. I created a new project, loaded my test spec and sure enough, when I place a lap flange it automatically adds the stub-end fittings.
I appreciate the replies and assistance from everyone! ![]()
Jason Drew
Support Specialist
Product Support
