• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Specs for AutoCAD Plant 3D
    585 Views, 4 Replies
    03-28-2010 04:39 PM
    Hi
    Any place where I can Download Specs for AutoCAD Plant 3D?
    Gracias
    Please use plain text.
    Active Contributor
    Re: Specs for AutoCAD Plant 3D
    03-29-2010 02:28 AM in reply to: guillermo.canon
    As far as I know there is no place where you can download P3D specs or catalogs.
    Peter Hammink
    Primat Project Service BV
    Employee
    03-29-2010 05:38 AM in reply to: guillermo.canon
    The specs that are provided by Plant 3D are located at (.pspc & .pspx files)
    C:\ProgramData\Autodesk\AutoCAD Plant 3D\Content\Specs
    The catalogs that are provided by Plant 3D are located at (.pcat files)
    C:\ProgramData\Autodesk\AutoCAD Plant 3D\Content\Catalogs
    For default installs
    Mike G (Autodesk)
    Michael Gulnac
    Technical Specialist
    Organization
    Autodesk, Inc.
    03-29-2010 03:38 PM in reply to: guillermo.canon
    Mike,
    What we need is to work with this Spec (please see attached file)
    Coudl you please let me know the general procedure to implement it? Is possible to get this files somewhere?
    Gracias
    Employee
    03-29-2010 05:47 PM in reply to: guillermo.canon
    The content that is included with Plant 3D catalogs is mostly ASME B16.10 and DIN. The specs are all based on the included catalogs. The spec sheets that you show looks to be clamped tube fittings. We currently do not have this type of piping content with Plant 3D. This is something that we will be adding in future releases.
    We currently do not offer a spec and catalog download. We inlcude them in the install
    Mike G
    Michael Gulnac
    Organization
    Autodesk, Inc.
