• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Accepted Solution
    Spec sheet grouping
    169 Views, 2 Replies
    11-29-2012 06:45 AM
    When I add flanges to my pipe spec, they appear undefr "Couplings" in the spec sheet and there is no "Flange" section on the sheet. How can I ensure there is a Flange section in the spec?
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: Spec sheet grouping
    11-30-2012 05:57 AM in reply to: tmccar
    are these flanges that you have created or ones from the supplied catalogs
    If you created them, did you make sure you had Flanges selected from the component category drop down box?
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    12-01-2012 03:30 AM in reply to: Rich.O.3d
    You're right - I remade them under "Flange" category and they now appear under Flanges when I add them to the spec. They had been created under "couplings"
