AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Spec Update
- Highlight
- Email to a Friend
- Report Inappropriate Content
why do we keep getting the spec update message when there have been no changes to the specs? i now it runs every few hours based upon user settings but if there has been no modifications to the spec why would it prompt me to apply changes?
Re: Spec Update
- Highlight
- Email to a Friend
I am having the same issue.
"Do or do not... there is no try"
Master Yoda.
Re: Spec Update
- Highlight
- Email to a Friend
<cough> <cough>
Re: Spec Update
- Highlight
- Email to a Friend
Have you checked your PLANTSPECNOTIFYTIME?
Set the time interval that spec files are checked for updates.
0 - Checks for spec file updates only when the drawing loads
1-4 Set the time interval (in hours) that spec files are checked for updates. The first check is made when the drawing loads.
You can also toggle it from ON/OFF with the PLANTSPECNOTIFY
Let me know if this helps.
Quentin Contreras
Support Specialist
Product Support
Autodesk, Inc.
Re: Spec Update
- Highlight
- Email to a Friend
I think the main issue, is that the spec has not changed, but the notice pop's up
Master Yoda.
Re: Spec Update
- Highlight
- Email to a Friend
turning it off or changing the time between checks does not fix the problem.
if a check is run and there are no changes to the spec then you should not get a message to "apply changes."
Re: Spec Update
- Highlight
- Email to a Friend
I think it is also checking to see if there are items in the model that need to be updated to match the latest spec descriptions. I think when you insert items, you get the latest data from the spec. So the spec update is more for checking descriptions compared to the model not necessarily whether there are new items in the spec.
One thing I've been recommending is that people do not modify the long description fields manually, as the spec update will overwrite those fields.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
