• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    Accepted Solution
    Small bore pipe support (dummy leg/stanchion)
    542 Views, 6 Replies
    01-21-2013 01:17 PM
    I'm a Plant 3D newbie.  We use the attached support quite a bit.  I'm not sure how to build this within P3D.  One thing I have tried is to create an AutoCAD entity and convert it to a pipe support.  This will attach it to the SW tee, but I'll still have the "drip" symbol.
    Any suggestions would be appreciated.
    Please use plain text.
    Product Support
    Re: Small bore pipe support (dummy leg/stanchion)
    01-24-2013 02:32 PM in reply to: EricNyh
    Can you provide a screen shot of what you have converted to pipe support? I would like to see where the "drip", disconnect marker, is being placed.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    01-25-2013 08:48 AM in reply to: quentin.contreras
    Attached is a JPG.
    My process for creating the support was to make an AutoCAD object, move it to the location, then use the PLANTPIPESUPPORTCONVERT command and chose the socket of the tee as the insertion point.
    Thank you.
    Active Contributor
    02-06-2013 05:46 PM in reply to: quentin.contreras
    Quentin,
    I didn't realize that you were the same person I had talked with on the phone, the other day, about my other issue with my line numbers not working.  :smileyhappy:
    You haven't happened to make any progress on this issue have you?
    Eric
    Product Support
    02-07-2013 04:54 PM in reply to: EricNyh
    I am sorry I did not get back to you before now. The easiest thing to do would be, for the threaded 3 way tee is just to place a plug. Then you could model your our support and convert support. This would also apply if you are using a SW tee.
    However, then you would have a plug that would show up in you BOM. The other option would be is the generate a custom tee with one end plugged.
    You can refer to this web link on creating Custom Companents.
    http://www.pdoteam.com/2011/10/custom-components-in-autocad-plant-3d/
    Let me know if this helps.
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    02-11-2013 05:07 PM in reply to: quentin.contreras
    Just checking to see if this helped or were you able to find another solution.
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    02-13-2013 08:29 PM in reply to: quentin.contreras
    Hello Quentin.  I finally got around to trying one of your suggestions.  I took a round plug and changed it's size to mimic a 4" long piece of round bar.  This seems to fix the "drip" connection.  As soon as I attach my pipe support to the plug, the "drip" reappears, but is only visable if you select the support.
    For the iso's, I can probably just create a new iso symbol for the round bar so that it includes the "duck" and then just fake the duck in the model.  If that makes sense.
