• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Accepted Solution
    Service Acquisition on pipe run components
    439 Views, 6 Replies
    10-02-2012 03:24 PM
    Is there a way to remove "acquisition" on selecting a service? I do not want to have to override the lines all the time.  I went into the project properties and went to <Plant 3D DWG Settings> down to <Pipe Run Component> and turned off <Acquisition> in the <Default Value> - then it just removed the Service field on the pipe runs.  So then I removed the Acquisition rule, and it still still does not fix the problem..
    I overrode the line colours to match what I want them to be and tied them to simple service types which I use.
    RS for recirc supply water - blue colour
    RR for recirc return water - red colour
    etc etc
    For my industry, this works great.. I don't care about having different colours for nominal sizes.
    I just want to easily change the service. Is there anyway to set this up? or a better way perhaps?
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Service Acquisition on pipe run components
    10-02-2012 05:46 PM in reply to: JohnHolder
    Easiest way I found to change the service is through the Data manager.  In 2013, there is an drop down at the bottom right to switch between object type and order by Area. When you choose Area, there will be a lines node, which represents the Pipe Line Groups.  With that level selected, you can select the service for the entire pipeline group.
    I assume you are using the layer automation from project setup?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Mentor
    JohnHolder
    10-03-2012 08:58 AM in reply to: dave.wolfe
    Yeah I found it, opened the line number and <service> is greyed out and locked.
    so I exported the data, unlocked the worksheet then changed the service
    relocked the worksheet and saved it.
    Imported the modified worksheet and nothing happened.
    I must be doing something wrong.
    Master Yoda.
    *Expert Elite*
    dave.wolfe
    10-03-2012 09:00 AM in reply to: JohnHolder
    Can you post a screenshot of the view of your data manager?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Valued Mentor
    JohnHolder
    10-03-2012 09:04 AM in reply to: dave.wolfe
    Here is the screen shot.
    I still have some untagged lines that I need to fix.
    edit
    1001 - RS
    200# - RR
    8001 - Wa
    Master Yoda.
    Product Support
    10-05-2012 06:45 AM in reply to: JohnHolder
    HI,
    If you select "Pipe Lines" from the list you can Export the active node, make the changes to the Service and then import those changes.
    Note the Service field is not grayed out in this view:
    It is also possible to make changes directly in the Data Manager.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Valued Mentor
    JohnHolder
    10-05-2012 12:31 PM in reply to: DanScales
    I see!
    I went one lvl too deep into the pipe lines.
    Thanks.
    Master Yoda.
