• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    marina.smirnova
    SQL and Report Creator
    380 Views, 14 Replies
    10-13-2011 07:24 AM
    I have a problem with Report Creation only for projects with SQL Expess.  With other projects everything is good.
    Please use plain text.
    Re: SQL and Report Creator
    11-29-2011 03:18 AM in reply to: marina.smirnova
    We have the same error with SQL.
    There is no dialog to log in.
    Eshleman78
    12-07-2011 07:14 AM in reply to: marina.smirnova
    Same issue here with the ProcessPower.dcf error.
    Board Manager
    12-07-2011 09:44 AM in reply to: marina.smirnova
    The Report Create will work with Windows Authentication for SQL Express. With SQL Authentication there is some issue opening project data and we are currently looking at it. Expect something soon on this.
    Mangesh Kalbhor
    Autodesk Plant Solutions
    Employee
    12-07-2011 09:46 AM in reply to: marina.smirnova
    Thanks for the heads up. We've confirmed that this is an issue and are working on it. As usual, I can't give any details on when it will be addressed.
    Peter Quinn
    Senior Product Manager
    12-08-2011 02:12 AM in reply to: marina.smirnova
    Thanks for recognizing the problem, I hope on a hotfix soon.
    Valued Mentor
    ybogdanov
    12-09-2011 05:03 AM in reply to: marina.smirnova
    Report Creator ne rabotaet v proektax kotorie podkreplenni s SQL serverom, tak kak SQL server imeet svoi sobstvennie vozmojnosti dlya formirovaniya dokladov, na primer Report Builder.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Active Member
    marina.smirnova
    12-09-2011 05:16 AM in reply to: ybogdanov
    Spasibo bolwoe, ybogdanov
    Active Member
    marina.smirnova
    01-25-2012 04:20 AM in reply to: marina.smirnova
    If anybody has the same problem and wants to use Report Creater with Project with SQL Express, there is one trick.
    In the project folder there is 4 files
     iso.dcf
    otho.dcf
    Piping.dcf
    ProcessPrower.dcf
    Then in every file after the Integrated Seguruty paste the following
    <Name>Integrated Security</Name>
    <Value xsi:type="xsd:boolean">false</Value>
    </Parameter>
    <Parameter>
    <Name>user id</Name>
    <Value xsi:type="xsd:string">sa</Value>
    </Parameter>
    <Parameter>
    <Name>Password</Name>
    <Value xsi:type="xsd:string">as</Value>
    </Parameter>
    <Parameter>
    sa - is the id name
    and as is the password
    After that everything works good.
    May be there is a way how to avoid this operation?
    Thank you very much
    01-25-2012 04:33 AM in reply to: marina.smirnova
    How to edit this files?
    I see only strange symbols..
