• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    StanleyMechanical
    Resistoflex Lined Pipe Catalog
    338 Views, 3 Replies
    02-16-2012 03:58 AM
    I recently downloaded the Resistoflex Lined Pipe Catalog from Autodesk Exchange.
    I am having issues with the isometric representation of the lined fittings, ie. the lined pipe spools show up as placeholders and fittings show up as welded fittings. Lined piping isometrics are required to show dimensions at each flange for exact dimensions of each spool and fitting.
    Has anyone else modified the downloaded catalog to show the correct representation of lined fittings?
    If so, how is it done and how difficult is it to achieve this?
    Thanks in advance.
    Please use plain text.
    Valued Mentor
    ybogdanov
    Re: Resistoflex Lined Pipe Catalog
    02-16-2012 12:32 PM in reply to: StanleyMechanical
    It's necessary revise SKEY and TYPE in the properties of the elements. Open Catalog Editor, and change it.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    05-14-2013 04:32 AM in reply to: ybogdanov
    Where did you find an Autodesk supplied Resistoflex Catalog? I just looked on the site and I'm not seeing where there is a content pack for that...
    Active Contributor
    05-15-2013 01:57 AM in reply to: StanleyMechanical
    Hi There
    The Resistoflex Catalog was removed from the site because of the errors in the Iso's produced.
    Once the errors are fixed hopefully it will be upload it again :smileyhappy:
    Kind Regards,
    Tarryn
