• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    Rcfuss
    Resistoflex Flange Navisworks Issue
    89 Views, 1 Replies
    07-03-2012 06:19 AM
    Has anyone had problems when viewing Lined Piping in Navisworks?  When I view the piping in navisworks the pipe segment flanges are white not the color line layer or service it is on.
    If I explode the pipe and match the properties of the line to the flanges that are white it works fine.
    Please use plain text.
    Valued Contributor
    andy.davis
    Re: Resistoflex Flange Navisworks Issue
    07-06-2012 09:02 AM in reply to: Rcfuss
    You're quite right.  I suspect it's the way that the flanges are added to the pipe and incorporated into the composite Plant item.  If you notice, when you select one of the flanges in Navis, the other is selected too.  The AutoCAD colour index  is always 7, white.
    You can always Presenter to 'paint' the pipe. :-)
    Andy
