• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    patpat78
    Accepted Solution
    Report multiple sheet
    136 Views, 6 Replies
    07-26-2012 08:18 AM
    hello
    i try to use the report creator for generating a report with all instrumentation
    easy :smileywink:
    i made  sorting list by supplier but i need to generate one excel sheet  by supplier is it possible ?
    thank's a lot
    Please use plain text.
    Active Contributor
    Re: Report multiple sheet
    07-27-2012 01:14 AM in reply to: patpat78
    Sure it is. Report Creator can create almost every list.
    Take a look at the video:
    ftp://acplant.net/Videos/ADSK%20Forum/PR_Grouping_120727.wmv
    Carsten
    Active Contributor
    patpat78
    07-27-2012 03:23 AM in reply to: cbeinecke
    OK very nice thank you
    but is it possible to put 1 supplier by sheet in excel ?
    because in the preview it ok but in excel not
    thx
    Active Contributor
    07-27-2012 04:22 AM in reply to: patpat78
    you can actually create various different file formats.
    After you selected the report click on Edit... (I hope that is what the button says in the English version). Under "Target" you can define the file type and the path/filename.
    For more details: go to http://docs.acplant.com/PlantTools/EN/PlantTools.html and look under: PlantReporter > Configuration > Create new configuration. Scroll down till hit find the topic "Output Type". Of course the whole chapter may be interesting.
    Carsten
    Active Contributor
    patpat78
    07-27-2012 05:26 AM in reply to: patpat78
    thank you very much it's work fine :smileywink:
    Active Contributor
    07-27-2012 05:31 AM in reply to: patpat78
    Tip: The layout of your report effects the layout of your Excel sheet. For example if you get very small columns in Excel it means that the objects in your layout are slightly either overlapping or they have a little gap between them. Just play a little with the position o the object to see the effect. If you understand how it works, you can start aligning all the object so the Exccel sheet looks nice.
    Carsten
    Active Contributor
    patpat78
    07-28-2012 04:21 AM in reply to: patpat78
    unfortunatly i was to quick to said it's work..
    in pict 1 you can see it's ok in perview
    but take a look of pict 2 the excel file....
    what i need it's the same as preview but in multiple excel sheet any idea ?
