AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Report multiple sheet
- Highlight
- Email to a Friend
hello
i try to use the report creator for generating a report with all instrumentation
easy ![]()
i made sorting list by supplier but i need to generate one excel sheet by supplier is it possible ?
thank's a lot
Re: Report multiple sheet
- Highlight
- Email to a Friend
Sure it is. Report Creator can create almost every list.
Take a look at the video:
ftp://acplant.net/Videos/ADSK%20Forum/PR_Grouping_
Carsten
- Highlight
- Email to a Friend
OK very nice thank you
but is it possible to put 1 supplier by sheet in excel ?
because in the preview it ok but in excel not
thx
- Highlight
- Email to a Friend
you can actually create various different file formats.
After you selected the report click on Edit... (I hope that is what the button says in the English version). Under "Target" you can define the file type and the path/filename.
For more details: go to http://docs.acplant.com/PlantTools/EN/PlantTools.h
Carsten
- Highlight
- Email to a Friend
thank you very much it's work fine ![]()
- Highlight
- Email to a Friend
Tip: The layout of your report effects the layout of your Excel sheet. For example if you get very small columns in Excel it means that the objects in your layout are slightly either overlapping or they have a little gap between them. Just play a little with the position o the object to see the effect. If you understand how it works, you can start aligning all the object so the Exccel sheet looks nice.
Carsten
- Highlight
- Email to a Friend
unfortunatly i was to quick to said it's work..
in pict 1 you can see it's ok in perview
but take a look of pict 2 the excel file....
what i need it's the same as preview but in multiple excel sheet any idea ?
