Report Creator Help
Report Creator Help
thebearjed
Report Creator Help
thebearjed
Where can i find documentation/tutorails/help on using the Plant Report Creator?
thebearjed
for example, report1.png is how what i am getting from the Report Creator. report2.png is what i want the Report Creator to do. i am trying to auto sum each individual category.
documentation can be found if you edit one of the reports and press F1 in the report designer. You will be guided to a on-line helpfile, but that is not what you're looking for. In the screen you see in-front of you, there is a link in the left menu at the bottom that says "Configure Reports". If you select this link a new screen will open and on that screen it shows a link to a pdf. This PDF is a 255 page large document that contains almost everything concerning the report designer.
To add components together so that you get an overview of the amount needed, the grouping section is of your interest. You also might try this link http://docs.autodesk.com/PLNT3D/2012/ENU/report_designer.pdf which should guide you direct to the pdf.
Barend-Jan (BJ) van Zijtveld
thebearjed
Thanks so much!
