• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Remove Coords from Isometrics
    589 Views, 7 Replies
    01-12-2012 07:56 AM
    i saw this post..http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Removing-Elevation-from-Isometrics/td-p/3286019...and was wondering if there is a similar way to turn off the coordinates on the isos?
    fyi, i unchecked the Append Coords box in project manager.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Remove Coords from Isometrics
    01-12-2012 12:41 PM in reply to: thebearjed
    In the project configuration, that tickbox for appending co-ordinates is for each type of End Connection Annotation. Make sure you scroll through each option and deselect the co-ord option.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Valued Mentor
    Rich.O.3d
    09-25-2012 10:07 PM in reply to: TomislavGolubovic
    cant seem to find out how to turn off the x and y co-ords but leave the z co-ord
    for 'cont'd on', 'cont'd from', 'connected to' ...etc annotations
    ie I just want:
    CONT'D ON:
    EL + 879
    not:
    E 896876
    N 789769
    EL + 879
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Employee
    TomislavGolubovic
    09-26-2012 04:48 PM in reply to: Rich.O.3d
    in 2012 or 2013 rich?
    Tomislav Golubovic
    Valued Mentor
    Rich.O.3d
    10-01-2012 04:10 PM in reply to: TomislavGolubovic
    doh..didnt i say...oops
    2012
    CAD Management 101:
    03-11-2013 06:34 AM in reply to: Rich.O.3d
    Did this question get answered.  I have the same situation and really need the fix.
    Valued Mentor
    Rich.O.3d
    05-04-2013 04:26 PM in reply to: jhamilton
    i havent been using plant for a while, no plant3d jobs in australia apparently (unless youve spent 20 years in an oil and gas job regardless of competence...dont get me started...lol)
    this was a core function the way the code was written, its not possible to toggle them individually, they are parsed as a single field entity with Easting Northing and RL
    i doubt if this has been changed, I chased this for a while back in 2011/2012 but got nowhere
    CAD Management 101:
    Employee
    TomislavGolubovic
    05-05-2013 03:23 PM in reply to: Rich.O.3d
    This is an answer I got about this
    Try this, turn off/uncheck the Append Coordinates and Elevation box under project setup for each End Connection Annotation type and open the Isoconfig.xml, search for “ElevationScheme – Elevation” or “ElevationScheme – ElevationExtended” and set the Enable value to “true”, use either 1 or 2 depending on how you want your elevation to be displayed.
    Tomislav Golubovic
