• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    milic.srdjan
    Accepted Solution
    Question - Pipe To Pipe Connection
    210 Views, 2 Replies
    03-21-2012 08:55 AM
    I have a New straight Pipe , e. g diameter 30" and I wish to connect to old one , same diameter 30",
    but, I can say "head to head" connection.
    New straight Pipe have PipeTag , e.g.   30"-1020-AASS
    Old straight Pipe have PipeTAG , e.g  30"-1020-AASS-RECO
    New Pipe have layer name same as Tag
    Old Pipe have name same as Tag
    After connection, all pipes keep their layers , BUT BUT...
    One straight Pipe take tag from another, and then I have one straight pipe with Tag 30"-1020-AASS, instead one straight pipe, with welding point, and two pipe segments, with two different PipeTags.
    Is it possible to avoid this...
    Milic
    p.s Is it possible to make straight pipe, with several different straight segments with several different PipeTag
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Question - Pipe To Pipe Connection
    03-22-2012 06:02 PM in reply to: milic.srdjan
    Place the length of pipe then add a field weld in the middle of it to split it? Then you can define different line numbers etc for each section, mark them as Existing or New etc.
    You can then change the type of weld from FFW/FW to a SHOP weld if you want also.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Valued Contributor
    milic.srdjan
    03-23-2012 04:44 AM in reply to: TomislavGolubovic
    Halo to Tomislav,
    Can I give 10 kudos :smileyhappy:
    This is great idea, great solution and I think We must put into Plant3D Course...A lot of time You have situation when You must make new pipe directly to old, in special in revamp...
    Thank You very much
    Srdjan Milic
    Spoiler
