AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Purge catalog reference from Spec
- Highlight
- Email to a Friend
Is there a way to purge a catalog reference from a spec?
Re: Purge catalog reference from Spec
- Highlight
- Email to a Friend
For what reason?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
- Highlight
- Email to a Friend
I don't know why the reason should matter? In this case, the catalog name changed, in the effort to create standardized naming conventions. Does that make a difference on whether I can purge a catalog reference or not?
- Highlight
- Email to a Friend
This will only work on specs that you have created.
You can use WinRAR to open the pspx file. Inside you'll find a folder called "editor".
In the editor folder, there is an .xml file, "CatalogReferences.xml"
This xml file contains the path for the Catalogs that are associated with the spec. You can change the Catalog name in the xml file.
Make sure you open the xml file from the WinRAR aaplication and when saving, it saves back to the archive.
Hope this helps.
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
- Highlight
- Email to a Friend
Thank-you Jarrod Mudford, for your help.
