AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Projects Units Problems
- Highlight
- Email to a Friend
Halo To all... ![]()
Last Friday, We have some server crash...Plant 3D projects are on server.
After that when We again start project, We have problem with Units for piping in project.
By default, was mixed unit project, piping was in imperial, and rest are in metrics. So, all pipes were in imperial, and everything
about piping were in imperial... e.g menu for building "new pipes" (routing new line" was with imperial diameters... e.g. specification viewer show components in imperial units.
Now By default all units are in metric.We can choose diameters by default in metric, and in brackets by side we have imperial
like 150(6")...
Is it possible to bring back, units to be mixed, default do be imperial for pipes, and rest metric...
Milic
Re: Projects Units Problems
- Highlight
- Email to a Friend
What Is this...No One...
No one had a similar problem
- Highlight
- Email to a Friend
If I read this correctly, are you sure you don't have the option for showing both Imperial and Metric in the pipe sizes? Its one of the buttons on the Ribbon, near the pipe size pulldown.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
- Highlight
- Email to a Friend
Yes, You are right for this.
I know for this option, (on a ribbon is a button for switching) but, what You will see, much depend from pipe class...
For e.g. If You have a pipe class only formed from imperial, you will see only imperial,
and if You have metric then You can see mixed units.... I hope than I explain good...
My problem was different. After collapse server with project on it, We have only metric units, and every thing was in some strange units. For e.g. isolation was in imperial, and piping were in metrics... Total confusion...
I found solution. I make new projects, set everything what I need, in projects properties, and then copy old drawings with piping, and steel, to new project....Everything was OK again...
Srdjan
