• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Fragels
    Problem with adding Lap-Joint : Collar not found
    915 Views, 6 Replies
    10-28-2010 07:21 AM
    Hi
    I'm trying to add a simpel Lap-Joint to my pipe.
    I keep getting the same error message with both my custom spec and a standard DIN spec.
    The flange has end type 1: FL and end type 2: LAP
    The collar has end type 1: LAP and end type 2: BV
    Is this correct?
    Is there any other property that can cause this fault?
    Attached a picture of the error message.
    BR
    Marcus Nyström
    Please use plain text.
    Employee
    RSFAdsk
    Re: Problem with adding Lap-Joint : Collar not found
    10-29-2010 06:47 AM in reply to: Fragels
    Hello Marcus,
    These can be tricky, but the first thing to check that all fasteners and adapters are in the spec.  The second is to insert the adapter from the spec viewer manually to verify it is there and see how it behaves (when inserting the adapter manually, the connection logic is simplified because only simple joints need to be created).  Finally take a look at the project connector settings.  If none of these things help maybe I can get size and details to try to recreate.
    See also: http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Disconnected-Message-on-joints/m-p/2666747
    Richard Frank
    AEC Plant Solutions
    Autodesk, Inc.
    Fragels
    11-01-2010 12:43 AM in reply to: Fragels
    When I use the Spec Viewer to add the flange I get no error message. But the collars and bolt marker is added as placeholders. And there is no gasket added at all.
    The Joint settings are setup as standard.
                          End 1                 End 2                   Fasteners
    StubLaped      LAP                   BV, PL                    Stub-end, Buttweld
    CollarLaped    LAP                   BV, PL                    Collar, Buttweld
    Flange             FL                        FL                         Gasket, Bolt set
    Exampel of joint i try to build:
    Pipe: ID DN50 (54x2mm)
    Collar ID DN50 (54x2mm) Lenght 45 Outside diameter: 102 mm Pressure class PN16
    Flange Outside diameter 165 mm Bore diameter 65 mm Thickness 19 mm Pressure class PN16
    Gasket 61x107x1.5 mm
    /Marcus
    Fragels
    11-01-2010 01:19 AM in reply to: Fragels
    I think I finaly got things working.
    I removed the line "CollarLaped" from the Joint settings. The error message dissapeared.
    Thanks!
    Employee
    RSFAdsk
    11-04-2010 10:11 AM in reply to: Fragels
    Glad to hear this is working for you.
    Yes if you have two or more joints that have the conditions, the first one listed in the Joint Setup Dialog is chosen (order set in defaultconnectorsconfig.xml).  You substitute to another joint type, or as you have done delete one that you do not want.
    Richard Frank
    AEC Plant Solutions
    Autodesk, Inc.
    Valued Contributor
    06-19-2011 11:13 AM in reply to: RSFAdsk
    Sorry to up this old post, but I want to set the priority for diferents conections that have the same end types, for example "StubLapped" and "CollarLapped". I open the file defaultconnectorsconfig.xml but in this file thereisn't nothing to change the priority of the connection. The StubLapped is the first than CollarLapped but the priotity is other (the first is CollarLapped).
    Employee
    RSFAdsk
    06-21-2011 09:29 AM in reply to: bogdanov.y
    Well to test, possibly you can <!-- comment  --> out StubLapped and check that CollarLapped inserts.  But it sounds like you have done things correctly.
    In the project's DefaultConnectorsConfig.xml, if everything else is equal and components for both types are available, then I expect the order of <joint> in <joints> to be used.  Possibly I can look at the XML or the project here.
    Richard Frank
    AEC Plant Solutions
    Autodesk, Inc.
