• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    PnPIso has stopped working
    206 Views, 7 Replies
    01-16-2013 12:38 PM
    When running iso's, there are a couple lines that cause PnPiso to stop working and errors out the ISO/PCF generator.  This seems to be a per computer basis, if someone else runs that same line it generates no problem, but when I do it, it errors out.
    I have cleaned graphics cache, run local data purger and even rebooted.  The only Thinkg I have not done yet is re-install and I am tryinig to avoid it.
    Any solutions to pnpiso fix?
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: PnPIso has stopped working
    01-16-2013 02:23 PM in reply to: blorich
    Does it work ok on your computer with another users login?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Valued Contributor
    01-16-2013 02:28 PM in reply to: TomislavGolubovic
    I will try this tomorrow.
    Valued Contributor
    01-16-2013 02:42 PM in reply to: blorich
    I tried this just now and the same problem, someone else logged on and the error happened again.
    It might also be worht noting that i do have Service Pack1 and the hotfix installed.    Now what I find funny is that there are 3 lines that I error on, but there are like 20 lines that do work.  When another computer runs those 3 lines they have no problems.
    Employee
    TomislavGolubovic
    01-16-2013 02:45 PM in reply to: blorich
    It does sound like a local computer issue. If the project works ok on other computers, and not ok on your computer, with different logins, then its something else.
    I'd try a repair installation? reinstall?
    Tomislav Golubovic
    Autodesk, Inc.
    Valued Contributor
    01-17-2013 01:30 PM in reply to: TomislavGolubovic
    I have uncovered some more information about this problem.   If I run a line on Check_ANSI_B style, it errors out, however another computer can run it no problem.  If I then change it to Check_ANSI_C size I run it no with no problem.   So if everyone who is running the lines is using the same project setup styles, how is it that some of them crash for me and others do not.
    Basically, what setting on my computer could be set differently than someone elses.  I haven't changed anything with the program at all(profiles, cuis, etc.), so any thoughts?
    New Member
    princeeng
    01-21-2013 02:53 PM in reply to: blorich
    Same problem here. I reinstalled plant 3d R13 still no luck. I get an error that says open drawing folder in windows explorer. Really need some help here, my job was due today, Tried new projects, folder settings, drawing recovery,
    checked all my pipelines and nothing works. Only happens when I try to produce iso's. Using windows vista 64 bit.
    New Member
    princeeng
    01-22-2013 11:13 AM in reply to: princeeng
    I put in a support request case still nothing from Autodesk. I have made mine work. I started by assigning one piece at at a time from my long line of piping to a different tag or line number, then generating iso's. I finally found one imperial custom part that was causing the problem. I would start with one piece and generate an iso, then adding a piece each time and generating an iso until I found which piece was causing the problem. Deleted the piece with the problem and re created it, now it works fine. I had created a custom part that had open end olets on it and I guess plant 3d did not like it. This took a very long time, I wish they would provide a way of checking for problems before you generate an iso. All this after an uninstall and reinstall and it was just a custom part that plant 3d didn't like in the line. I hope this helps someone.
