• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    PlantPipeAdd problem
    193 Views, 6 Replies
    07-23-2012 12:05 PM
    I created this customed knife gate valve, sizes ranged from 12 to 30".
    All size work except 22".
    Error message, size not in placeholdspec, any idea?
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: PlantPipeAdd problem
    07-24-2012 03:18 AM in reply to: Kumquat
    There is a placeholder spec thats part of the project, its like a temporary part placement for something that might be missing in a working spec.
    Can you post your spec please and i'll see if i can work out what you're missing?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Active Member
    07-24-2012 08:26 AM in reply to: Kumquat
    Hi Tom, Thanks for your reply. Please see attached spec. Dennis Tham Mechanical Cadd/Designer Klohn Crippen Berger 500 - 2955 Virtual Way, Vancouver BC V5M 4X6 CANADA D 604.251.8472 | T 604.669.3800 | F 604.669.3835 | dtham@klohn.com | www.klohn.com
    Active Member
    08-22-2012 02:59 PM in reply to: Kumquat
    Hi Tom,
    Is there anyway to edit placeholder spec?
    Spec Editor said that I can only edit placeholder in Plant 3D.
    See Below.  The imperial size is available.
    Thanks in advance.
    Employee
    TomislavGolubovic
    08-22-2012 03:24 PM in reply to: Kumquat
    Hi, are you sure you attached the spec? Also the images you just added are too small to see?
    Tomislav Golubovic
    Active Member
    08-22-2012 03:45 PM in reply to: Kumquat
    Hi Tom,
    I am still using Plant 3D 2012.
    This is the default placeholder spec.
    The imperial size has 22".
    The metric size skid over 22".
    Do you know if this problem is fixed on 2013.
    Employee
    TomislavGolubovic
    08-26-2012 03:29 PM in reply to: Kumquat
    I don't understand why you are using the Placeholder spec to build items with. You should be using a CS150, or Stainless Spec, or something that the customer/engineer wants to use. I wouldn't be using the Placeholder spec for anything at all.
    Tomislav Golubovic
