• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    Plant3d 2012 cut piece list issues.
    588 Views, 9 Replies
    09-12-2011 01:02 PM
    I am having issues with the lengths calculated in the cut piece list not matching what I calculate using the given dimension minus the take-outs for fittings. Some lengths are off 1/16" and some as much as 9/16". Is there a settings for rounding up of cut length in the config files somewhere? Any one else experiencing this problem? This was brought to my attention by our pipefitters.
    Please use plain text.
    Valued Contributor
    pkw167
    Re: Plant3d 2012 cut piece list issues.
    09-14-2011 06:24 AM in reply to: chad70811
    It could be the GAP value in project setup.
    Valued Contributor
    09-14-2011 11:39 AM in reply to: pkw167
    Thanks but I have checked the GAP sttings already. It looks like the cut list is rounding all fractions up to the neasrest inch. Autodesk is there a setting in one of the config files I need to adjust? I can post my model and iso if that will help troubleshoot this issue.
    Valued Mentor
    Rich.O.3d
    09-14-2011 02:28 PM in reply to: chad70811
    are you using 'engagment length' on your joints/fittings they will affect the cut lengths, also when you edit parts in the catalogue, you will see some dims that set the location for the node to be away from the connection face.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Employee
    VickyADSK
    09-22-2011 02:29 AM in reply to: chad70811
    Open Isoconfig.xml in project folder. e.g. Project\Isometric\Final_ANSI-C
    Change Precision value to Precision5.
    <Style Name="ImperialPipeLength" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="."/>
    In this case, the total length of pipe in BOM will rounded as well since both pipe length in BOM and cut piece length use the same style.
    Vicky
    Autodesk Plant Solutions
    Valued Contributor
    09-22-2011 05:09 AM in reply to: VickyADSK
    Thanks Vicky that fixed my problem. But I have one more question, do you know how to change the dimension style to show feet and inches (ex: 1'-4 3/8") instead of inches only (ex. 16 3/8"). Sometimes the iso program dimensions in feet and inches and on other dimensions on the same drawing  it will dimension in inches only. I have attached a dwg as an example.
    Chad
    Employee
    VickyADSK
    09-22-2011 05:41 PM in reply to: chad70811
    It should be a bug. But i couldn't see the issue from my side. Could you please post the PCF as well? isoconfig.xml is a plus.
    Vicky
    Valued Contributor
    09-23-2011 03:57 AM in reply to: VickyADSK
    I have attach the pcf and isconfig.xml per your request.
    Employee
    VickyADSK
    09-26-2011 12:50 AM in reply to: chad70811
    Sorry for my mistake. There's a settings in isoconfig.xml to change the dimension style in project folder.e.g. Project\Isometric\Check_ANSI-B\IsoConfig.xml
    The default value is 24" which means less than 2 feet will be shown as inches, e.g. 18". Change it to 12" then you could see 1' 6"
    <Dimensions Enabled="true" OffsetDistance="0.6" StackingDistance="0.4" ShowHacheMarks="true" HacheMarkSymbol="GasketHacheMark" HacheMarkOffset="0.0625" ImperialDimensionInchCutoff="24">
    Vicky
    Valued Contributor
    09-26-2011 06:53 AM in reply to: VickyADSK
    Thanks Vicki, that is exactly what I was looking for.
