• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    followsea
    Plant 3d and ASD cannot cooperate seamlessly?
    570 Views, 7 Replies
    12-18-2011 08:51 PM
    I use Plant Design Suite. I make steel structure in ASD, then xref it in Plant 3D. Problems is:
    1.After Object Enabler installed, ASD models display  detailed(show all roundings etc). This reduce the progame performace seriously. No tools can control it in Plant 3D. Settings in ASD PREFERENCES doesn't affect it either.
    2.With regard to ASD models, Osnap cann't work in Plant 3D like that in ASD. I cannot snap almost all contour vetex or midpoint. This makes assembling with other objects in Plant 3D so difficult.
    3. When generate Otho drawing of models including ASD models, the result is so bad.(So useless detailed lines).
    Any ideas helpful? Thanks!
    Please use plain text.
    Product Support
    jason.drew
    Re: Plant 3d and ASD cannot cooperate seamlessly?
    01-04-2012 12:06 PM in reply to: followsea
    I will check with the development team on these issues and give you an update as soon as possible.
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Product Support
    jason.drew
    01-25-2012 07:40 AM in reply to: followsea
    The object enablers for AutoCAD Structural Detailing have recently been updated. Please download, install and let us know the results:
    AutoCAD Structural Detailing 2012 Object Enablers (32-bit and 64-bit)
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    followsea
    02-15-2012 07:21 PM in reply to: jason.drew
    Only resolve the display(Detailing or without roudings, configured in ASD) when you directly open the ASD file in P3D. But when XREF it in P3D, it display detailing, regardless of the configuration.
    All other problem  exist.
    Another improving is good. P3D can XREF ASD formworks model now, while it always collapse before. But another problem arise: the axis number dissaper when xref it in P3D.
    Thanks.
    Member
    kmayland
    02-18-2012 04:50 PM in reply to: followsea
    may be the intelligent SDNF import interface for AutoCAD PLANT 3D is an opportunity for you? Get in contact with Unitec.de for further details.
    Distinguished Contributor
    Arun_Kumar_K
    07-11-2012 08:48 AM in reply to: kmayland
    The same issue we are facing now?
    How Autodesk didn't answer this question for more than a year?
    Arun_Kumar_K
    07-12-2012 12:09 AM in reply to: followsea
    Looking for prompt answer from Autodesk in this regard.
    Product Support
    jason.drew
    02-06-2013 08:39 AM in reply to: followsea
    One workaround that has been suggested to me is using "Save model to ACIS solids" from ASD:
    This will save the ASD model to a .DWG which can be copied into Plant 3D and attached as an XREF. Object snaps will work and all connection detail (plates/bolts/etc.) will display in the model and on the orthographic views.
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
