• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Plant 3d Reports
    131 Views, 2 Replies
    04-28-2012 11:55 AM
    Major issue with the reports...
    In one drawing I have 2 styles of tanks.  2205 model and 2805 model.
    Short Discription : Tank
    Long Description : Aquacare 2205
    Long Description : Aquacare 2805
    with the report creator, it would make sense that under the title "Tank"
    there would be TWO lines
    2Aquacare 2205
    4Aquacare 2805
    but for some reason ?!?!
    6Aquacare 2205
    Do I seriously have to have a single short description for EACH and every tank style?
    this still applies to reducers and most likely ells aswell...
    edit : it seems to if I add a nozzle the tanks are seperated... but these tanks do NOT HAVE NOZZLES.
    they have a different long discription.
    So it seems like if the short description is the same - they all must be identical?!  even when they have different long descriptions?
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    Valued Mentor
    ybogdanov
    Re: Plant 3d Reports
    04-29-2012 02:12 AM in reply to: JohnHolder
    It's bad configuration of grouping. Revise it. In your case the program grouping only with short description, is necessary to add another level of group "Long description".
    In the "Edit Layout" down part of screen.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Valued Mentor
    JohnHolder
    04-29-2012 07:52 AM in reply to: ybogdanov
    Thank you!  I managed to figure out the tanks... now the test is for the reduction bushings to see if that sorts properly.
    John.
    Master Yoda.
