• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    Plant 3D sloped pipe to slip on flange
    212 Views, 5 Replies
    02-10-2013 03:26 AM
    Hi I was just wondering if anyone could help me, we have several cases on site where a sloped pipe goes directly in to a slip on flange. Is there a built in tolerence of how much of a angle the pipe can be before it can be connected direct to the pipe and can this angle be altered?
    thanks
    Please use plain text.
    Product Support
    Re: Plant 3D sloped pipe to slip on flange
    02-20-2013 09:29 AM in reply to: mgoldsmith
    You can edit the tolerance for your joint in the DefaultConnectorsConfig.xml that is located in the root folder of the project.
    This is a section for the connection that you need to edit:
    <SlopeTolerance>3</SlopeTolerance>
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Distinguished Contributor
    Ahmed1081975
    02-20-2013 10:42 PM in reply to: mgoldsmith
    Hi Dan,
    I’m sorry to say your answer not sufficient to me please can be more detail with screen snapshot
    Ahmed Helal
    Product Support
    02-21-2013 03:47 AM in reply to: Ahmed1081975
    I have attached a screen shot from the DefaultConncetorsConfig.xml below:
    You need to edit the SlopeTolerance to the required angle.
    Dan
    Dan Scales
    Autodesk, Inc.
    Ahmed1081975
    02-21-2013 04:00 AM in reply to: DanScales
    Thanks For all of you
    Ahmed Helal
    New Member
    02-21-2013 04:15 AM in reply to: DanScales
    Hi Dan, I have tried this and I still cannot connect to the flange.
    I have a funny feeling though that my project is looking at the wrong DefaultConncetorsConfig.xml file. Is there a way to check if the path to this is correct?
    I have changed the tolerance to 5% perhaps this is to much?
    Mathew
