• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Plant 3D 2013 Isometric Output
    673 Views, 4 Replies
    11-05-2012 10:53 PM
    I've started using Plant 3D 2013 and have a few questions.  (See attachment).
    1. Highlighted in pink, these dimensions are a bit odd.  Plant 2012 never dimensioned in this way and was  just wondering if the dimension could go all the way to the IP point rather than the weld lines.
    2. I have a pipe support which has a tag number but for some reason the tag is not appearing on the iso.
    3. The annotations circled.  Is there a way to remove these from the isometric.  Maybe in the xml file.
    4. The annotations clouded.  Again, can these be removed from the iso.  It just clutters the iso with unnecessary and repeat information.
    Thanks all.
    Jason
    Please use plain text.
    Distinguished Contributor
    Ahmed1081975
    Re: Plant 3D 2013 Isometric Output
    11-06-2012 12:33 PM in reply to: JasonDavis73
    I have Also Isometric output please refre the attached snapshot
    We need help
    Ahmed Helal
    Member
    11-06-2012 07:40 PM in reply to: JasonDavis73
    Hi all,
    Well I have managed to figure out how to get points 2, 3 and 4 to work.  All done through the isoconfig.xml file.
    Still having problems though with the first point.  It's strange because 2012 worked perfectly.
    Cheers,
    Ahmed1081975
    11-06-2012 08:35 PM in reply to: JasonDavis73
    Hi All,
    Another One proplen in dimension Settings For Isometric please Rfer to Screen shot
    Ahmed Helal
    Active Member
    04-02-2013 01:51 AM in reply to: JasonDavis73
    Hi there,
    I realise this is a bit late as your posts were roughly a year ago, however i was wondering if you could advise me on how you got point 4 to remove from the iso, specifically the line size text that is arrowed to the line, In your example the 10" text. Most annoying.
