- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Day
Below is an image of a typical fabricated bend which is used for rubber lined pipe.
Elbow with collar welded onto the ends, item then rubber lined , backing rings to fasten item.
Main reason for this configuration is if the pipe is slightly misalligned can compensate for this.
Would like this item to be one component on the bill of materials as fabricated and purchased like this?
Is there a way to be able to do this in plant 3D, this has to be a specification component, not user item!
Any suggestions or workarounds "as usual" welcome
Backing ring would typically be a FL and LAP connections.
Could we not have a elbow and a stub end welded together? "to be one item in BOM? then also fine.
Any assistance most welcome
Thanking You in Advance . . . .
