• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    Piping Service Code
    417 Views, 3 Replies
    11-15-2011 11:47 AM
    How do I set the service code on a line prior to running the 3D pipe? I am using Plant 3D 2012.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Piping Service Code
    11-15-2011 05:36 PM in reply to: JOHNMCDOWELL8178
    In the ribbon, when you click on the pulldown marked "Route New Line" if you have the Service setup in the Line Code, then you can input the service there. If not, then run the line, right click on it, and set it in the properties.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Active Member
    11-16-2011 04:43 AM in reply to: TomislavGolubovic
    Thanks for your reply. Can you explain how to set up Service in the Line Code under "Route New Line"?
    Product Support
    jason.drew
    11-18-2011 02:56 PM in reply to: JOHNMCDOWELL8178
    Hi John,
    In reply to Tom's suggestion, here is some additioal information on the line group tags.
    Configuring the service for the pipe run prior to routing would require a line number tag configuration in Project Setup similar to this:
    Which allows the service to be set before routing the pipe:
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
