• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    sap_joakim
    Pipesupports on sloped pipe fail!
    137 Views, 0 Replies
    08-30-2012 01:01 AM
    Have problems snapping an support on a sloped pipe in a 3D model. Previous versions of plant 3D had no problems doing this. as you can se in the picture. The support at the bottom is made in a prevous version (2012) and then megrated to 2013, and now when i want to continu adding supports it does not orientate corectly as you can se. Is there an setting for this or an hotfix ?
    I use 3d snapp to posision the support,
    In 2012 the sopport orientated corectly on the sloped pipe without any problems.
    Regards
    Joakim
    Please use plain text.
