• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    jpeters
    Pipe missing flanges in iso
    192 Views, 2 Replies
    03-09-2012 08:07 AM
    In my Iso drawings I have FLxFL pipe & fittings.  The flanged ends of the fittings are showing up correctly but pipe is coming out with no flanges.  See attached screen shot.   From what I understand about the SKEY mapping file, the end connections drawn are based on the end connection codes (FL) of the part.  My mapping files points FL to the FittingFlange block.  Both my fitting and pipe use the FL code so shouldn't they both come out the same in iso... what am I missing?  Thanks!
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Pipe missing flanges in iso
    03-09-2012 12:15 PM in reply to: jpeters
    You have to create your own symbol keys.
    We have an article how to do that here:
    http://www.pdoteam.com/2011/10/create-new-symbols-for-isometrics-in-autocad-plant-3d/
    I ended up putting creating a PIFL key.  You can't use the PIPE type because the isometric program just draws lines.  You can use a different type like ELBOW.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    jpeters
    03-12-2012 11:08 AM in reply to: dave.wolfe
    Dave,  Thanks (again!) for your reply.
    Let me make sure I have this straight:  When the system sees an Iso Symbol Type of PIPE it ignores the end types and doesn't use the mapped connection symbols.  So in the catalog/specs for flanged pipe you change the Iso Symbol Type to something else, say ELBOW.  Then you add an SKEY that maps to a symbol that is a straight line (to represent the pipe).  Because the Iso Symbol Type is not PIPE it looks for the end types and applies the appropriate symbols?
    I've seen no documentation for Iso Symbol Types... Is there a list out there.  Or a file or dialog box that defines them?
    Thanks!  -Jason
