AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Pipe and Slip on Flange Dimension incorrect in ISO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi There,
I wonder if anyone can help me. I am pulling an ISO of a pipe which contains a slip on flange. The end types for the flange are: 1. FL and 2. SO. When I pull the ISO it should show a dimension of 600 including the flange width. The pipe was created with a length of 600. But when I add the flange to the pipe it adds the additional 14 (Flange thickness). Therefore my dimension in my ISO is 614 instead of 600. Is there a way to change this so that the flange sits over the pipe instead of infront of it? I tried changing the engagment length in the catalog editor. It put the flange 14mm infront of the pipe, but no matter what sizes I changed it to I could never get the flange to sit on the pipe.
Kind regards,
Tarryn
Re: Pipe and Slip on Flange Dimension incorrect in ISO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As I understand correct, You need do have one point on a slipon flange, that contains two attachment point, one for a pipe (SO) and one for a flange (FL), as You wrote,
When we look at B16.5, please, You can find that this two points are slightly different, not the same.
When You change a component in catalog, reload again in pipespec, then test it.
I saw in catalog that they have a little difference from L and I values.
You must also check "way of dimension" for ISO template form. I suppose that You can check length of pipes in cut piece list, is it correct or wrong.
@end, this is interested problem, because on a big flanges this difference can be big.
e.g For 16" SO Flange L-I 2.5"-2.34"=0.16" (>4 mm), then if you have 10, or 20 flanges on a line , it goes > 8 cm
