• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Pipe Weld Joint Symbol in Ortho Drawing
    394 Views, 5 Replies
    12-06-2011 06:41 AM
    Does anyone know if there is a way to have a standard symbol auto-inserted at each field weld location on an Ortho Drawing?
    Please use plain text.
    Product Support
    jason.drew
    Re: Pipe Weld Joint Symbol in Ortho Drawing
    12-07-2011 08:18 PM in reply to: rigginc
    Are you looking for weld numbers similar to the Isometric drawings?
    Jason Drew
    Support Specialist
    Product Support
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Member
    12-08-2011 06:12 AM in reply to: jason.drew
    I am looking to have a symbol show up so that we can clearly see the location of a field weld.  Currently there is just a line which is hard to see unless the scale is large enough.
    Product Support
    jason.drew
    12-09-2011 02:53 PM in reply to: rigginc
    Are you using Plant 3D 2011 or Plant 3D 2012?
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Member
    12-13-2011 10:59 AM in reply to: jason.drew
    Plant 3D 2012.
    Product Support
    jason.drew
    12-15-2011 10:14 AM in reply to: rigginc
    Thank you for the reply back. I will pass this along to the team as a feature request for 2012.
    With regard,
    Jason Drew
    Support Specialist
    Product Support
