• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    Pipe Support problem with sloped pipes P3D 2013
    148 Views, 1 Replies
    01-21-2013 12:13 AM
    The pipe supports do not rotate and align to the pipe when I have a Sloped Pipe. Is it possible to change any settings in the program to make the pipe supports align with the pipe slope?
    Please use plain text.
    New Member
    Re: Pipe Support problem with sloped pipes P3D 2013
    01-28-2013 10:34 PM in reply to: Stefan_WSP
    I have the same problems. But you can rotate the support after attaching it to a pipe. this is what i have been doing on my sloep pipes. after you have rotated a support you just copy that one to youre next location using array with slope after pipe. remember to use Reference when you rotate the support sp you get it exactly right on the pipe :smileyhappy:
    Good Luck
