• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    Pipe Support .acat & support palete help needed
    453 Views, 11 Replies
    01-06-2012 04:32 PM
    I have created a couple of supports with the pipe support.acat - no problems.
    However how do you get these on to the pipe support palette within P3D - there must be a way of adding new ones from the .acat file.
    Help would be appreciated
    Gary
    Please use plain text.
    Product Support
    Re: Pipe Support .acat & support palete help needed
    01-09-2012 06:12 AM in reply to: MOLGRAND
    Hi Gary,
    You can open the pipe support in the spec editor and change description, skey for Isometrics etc, but it is not possible to create a new one.
    The ability to add custom supports in the catalog has been logged as a wish list item with out development team.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Valued Contributor
    02-27-2012 06:50 AM in reply to: DanScales
    But as i know,when we create support in Plant 3D,those parameters are not from SUPPORTS Catalog.acat.
    i find a support just like pipe hanger in SUPPORTS Catalog.acat,we can see that these parameters are not the same as those when create in Plant3D.
    And in SUPPORTS Catalog.acat,the description are not the same as those when create in plant 3D.
    So where does these parameters come from?or where is the default value that we can modify?
    Active Member
    scottscs71
    01-25-2013 07:34 AM in reply to: MOLGRAND
    This has to be addressed.  I am working on Aux Steel Supports and now find out we cannot add them to the catalog.  What is the projection for this getting added?
    _________________________
    Scott Hallmark
    Inventor 2013 Certified Professional
    Employee
    01-28-2013 09:47 AM in reply to: scottscs71
    In 2013, look in the PipeSupportsSpec in your project.
    Peter Quinn
    Senior Product Manager
    Autodesk, Inc.
    Active Member
    scottscs71
    01-28-2013 10:41 AM in reply to: PeterQuinn
    I understand we can add them to the spec.  The problem I am having is adding my custom items to the catalog.  I have generated the Python scripts and registered them and the objects show up in my list in the catalog  when I choose "create new component" but error out when trying to add to the catalog.  I get this:  "Column 'SizeRecordId' is constrained to be unique. Value '' is already present."
    I thought it might be my script but I get the same error when using an out-of-the-box parametric support in P3D.  It will not let me add to the catalog.  I am using 2013 SP1 G.114.0.0
    Scott Hallmark
    *Expert Elite*
    dave.wolfe
    01-29-2013 05:30 AM in reply to: scottscs71
    Once you define the script in the python file, you have to use the activate function to let Plant 3d know how to handle it.
    The parameters D - WD are used by the script, I believe the rest of them are what is necessary to work with the catalog.
    activate(CUSTOMSCRIPT,
    [Type AQA-CUSTOMSCRIPT]
    VID=STRING,32
    DN=STRING
    D=LENGTH
    RD=LENGTH
    RL=LENGTH
    RDI=LENGTH
    RLI=LENGTH
    RLIU=INT
    RTYPE=INT
    W=LENGTH
    WD=LENGTH
    Units=STRING,8
    uniqId=CALC =$self.VID$ $self.DN$ $self.RTYPE$
    @key=VID,DN
    "@VarDataDefault0",
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Arun_Kumar_K
    01-29-2013 07:06 AM in reply to: MOLGRAND
    Request Autodesk to educate all the users about coding custom supports using python.
    *Expert Elite*
    dave.wolfe
    01-29-2013 07:17 AM in reply to: Arun_Kumar_K
    That's part of being an ADN member.  They have documentation available when you are an ADN member since this is development...not really a part of using the program.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Active Member
    scottscs71
    01-29-2013 12:37 PM in reply to: dave.wolfe
    This is the top of my code:
    from aqa.math import *
    from varmain.primitiv import *
    from varmain.var_basic import *
    from varmain.custom import *
    @activate(Group="Support", TooltipShort="AS-26", TooltipLong="AS-26 Aux Support", LengthUnit="in")
    @group("MainDimensions")
    @param(HWL=LENGTH, TooltipLong="Horizontal W-Shape Length")
    @param(WSIZE=LENGTH, TooltipLong="Horizontal W-Shape Size")
    @param(HWV=LENGTH, TooltipLong="Horizontal W-Shape Over-Hang")
    def AS26W(s, WSIZE=4, HWL = 24.0, HWV=3.0, ID = 'AS26W', **kw ):
    This is the bottom of my code:
    activate(AS26W,
    [Type AQA-VAS26W]
    VID=STRING,32
    DN=STRING
    WSIZE=LENGTH
    HWL=LENGTH
    HWV=LENGTH
    Units=STRING,8
    @key=VID,DN
    "@VarDataDefault0",
    As long as the bottom of my code is commented out (the "activate" portion), it works and generates the object.  If it is removed, I get this in my command prompt:
    Command: (arxload "PnP3DAcpadapter.arx")
    Command: PLANTREGISTERCUSTOMSCRIPTS
    Command: Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File ".\variants\varmain\custom.py", line 366, in dumpAll
      File ".\variants\varmain\custom.py", line 323, in dumpAll
      File ".\variants\varmain\custom.py", line 305, in dumpFile
      File "c:\autocad plant 3d 2013 content\cpak common\customscripts\AS26W.py", line 131, in <module>
        "@VarDataDefault0",
      File ".\variants\varmain\custom.py", line 192, in __new__
      File ".\variants\varmain\custom.py", line 210, in __call__
      File ".\variants\varmain\custom.py", line 67, in metadata
    AttributeError: '_SCRIPT' object has no attribute 'func_metadata'
    Scott Hallmark
