• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    sap_joakim
    Pipe Segments most be greater then 5mm?
    324 Views, 6 Replies
    10-20-2011 03:03 AM
    I get the message "Minimum pipe length most be greater then or equal to 5" when trying to set it to 0.
    Is there any way to set this to 0 ?
    Realy need to have the option to use bend in bend with no segments.
    regards
    Joakim
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Pipe Segments most be greater then 5mm?
    10-20-2011 06:25 PM in reply to: sap_joakim
    What are the two end conditions of the bends?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Active Member
    sap_joakim
    10-20-2011 11:38 PM in reply to: sap_joakim
    Thx for the reply but can you bee more specific on what information you want,
    By end condition you mean if its a BW FL PL and so on?
    If so it is BW.
    There is no problem roting a pipe with bends but if you need to do a 180degres turn and only use 2 bends connected to each other witout a 5mm pipe segment betwin them the problem comes.
    I also for an exampel whant to do a side cast with 2 bend there still need to be a 5 mm minimum segment, This is what i dont want.
    Look at IMG for more info. The marked pipesegment betwin the bends is what i want to remove and have the 2 bends connected directly to each other.
    Valued Mentor
    ybogdanov
    10-20-2011 11:46 PM in reply to: sap_joakim
    If so it is BW.
    To do this: delete the pipe segment and insert the another bend from tool palete of your spec (connecting with the first bend directly)
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Active Member
    sap_joakim
    10-21-2011 01:08 AM in reply to: ybogdanov
    Thx for the help.
    But this is hard to do if you have a specific distans you need to go sideways. Then you need to know the degrees of the bend before roting the bend.
    If im for an exampel use line to Pipe i can specify the exact lokation of the center of the bends, but when i use line to pipe command and the distans is shorter then the Bend radius then Plant 3d dont understand to put bend to bend direcly. Insted it dissconnect the pipes like shown in the new IMG, maby this is another topic togh.
    Employee
    TomislavGolubovic
    10-23-2011 06:46 PM in reply to: sap_joakim
    Can you post the dimensions of the centrelines, or even post the model? I'd like to have a look at this and give a workaround if possible.
    Tomislav Golubovic
    Autodesk, Inc.
    Active Member
    sap_joakim
    10-23-2011 10:24 PM in reply to: sap_joakim
    Hello and thx for looking in to my problem.
    Here is a drawing on the pipe in the earlyer IMG.
    The dimention of the pipe in this exampel is DN200.
    And if possible can you look in to how to tell autocad to not do a pipe segment automaticly betwin bends. I need this to be 0 not a minimum of 5mm.
    Regards
    Joakim
