• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    PLANT 3D Structure Problem
    115 Views, 2 Replies
    04-27-2012 09:40 AM
    hello,
    I have this issue in both 2012 and in 2013.
    Anything structural that is inserted into the model if "off" by a bit.
    try drawing a line, then create a member from this line. zoom in and you will see how it is "off"
    This casues major issues and problems. If you dont catch this right away it will domino effect all the way through your structure and you will end up with one screwed up model.
    help!!!
    thanks
    rory
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: PLANT 3D Structure Problem
    04-28-2012 02:03 AM in reply to: roryromano
    When you click on the Member Settings are the offsets for the Member set to 0?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Active Contributor
    04-30-2012 05:25 AM in reply to: TomislavGolubovic
    yep, set to 0, still comes in "off"
