AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
PID to 3D End Connection Mapping
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having an issue when placing components from my P&ID line list...
When I place a valve from my line list the end connections are incorrect.
Attached image 1 is of the model and placed plug valve...
Attached image 2 is of the PID with flanged plug valve...
Attached image 3 is after I replaced the valve through the replace glyph... note the tag information was removed...
Note:
1. The properties in image 1... end connections are flanged, but the valve is a butt weld type...
2. This was all in an out of the box Plant 3D 2011 project.
3. The end connection mapping would be less of an issue if I could replace the valve without having to reenter the tag information...
I am wondering if this is a limitation of plant 3D 2011, and if this issue was resolved in the 2012 release?
Does anyone know of a workaround for this problem?
Stassel
Re: PID to 3D End Connection Mapping
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The insertion methods follow the spec. So, the highest priority item gets inserted. The tag gets replaced in 2012; we are working on getting that resolved.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dave,
Thank you for your reply!
Is there a way to add criteria on the 3D model inserted from the P&ID line list? So I wont have to replace the valve and edit the tag every time? If not is this something that is being worked on?
Stassel
