• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Stassel
    PID to 3D End Connection Mapping
    207 Views, 2 Replies
    03-07-2012 07:16 AM
    I am having an issue when placing components from my P&ID line list...
    When I place a valve from my line list the end connections are incorrect.
    Attached image 1 is of the model and placed plug valve...
    Attached image 2 is of the PID with flanged plug valve...
    Attached image 3 is after I replaced the valve through the replace glyph... note the tag information was removed...
    Note:
    1. The properties in image 1... end connections are flanged, but the valve is a butt weld type...
    2. This was all in an out of the box Plant 3D 2011 project.
    3. The end connection mapping would be less of an issue if I could replace the valve without having to reenter the tag information...
    I am wondering if this is a limitation of plant 3D 2011, and if this issue was resolved in the 2012 release?
    Does anyone know of a workaround for this problem?
    Stassel
    Please use plain text.
    dave.wolfe
    Re: PID to 3D End Connection Mapping
    03-07-2012 09:54 AM in reply to: Stassel
    The insertion methods follow the spec.  So, the highest priority item gets inserted.  The tag gets replaced in 2012; we are working on getting that resolved.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Stassel
    03-07-2012 12:20 PM in reply to: dave.wolfe
    Dave,
    Thank you for your reply!
    Is there a way to add criteria on the 3D model inserted from the P&ID line list? So I wont have to replace the valve and edit the tag every time? If not is this something that is being worked on?
    Stassel
