AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
PCF file template
- Highlight
- Email to a Friend
Hi,all!
I don't know if there is a template for the pcf file when I create isos.
Sometimes, I must modify the pcf file handly to make a better isometric. Obviously it's not very convenient. So if there is a template file, this will be esay!
Anyone knows that? Thanks!
Bin.
Re: PCF file template
- Highlight
- Email to a Friend
What do you need to update? Its all done within the Isometrics dialog box and the XML file.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks, Tom!
You know that we can have lots of options in the isoconfig.xml. But some of the data format can't be set up. For example, the tag is unique. Assume that we have five similar valves, and the tags are HA-1, HA-2, and so on. But in the isometric, we just need to annotate 'HA'.
So we must modify the pcf handly. If there is a template, I think we can make that more easier.
- Highlight
- Email to a Friend
You could modify an annotation scheme for valves to display a different property. For example, I think the property you would want to display would be the valve code (vs the tag). Then you'd get HA without the valve number.
We have several posts on using an xml editor for various tasks like this:
http://www.pdoteam.com/?cat=100
http://www.pdoteam.com/2012/08/editing-xml-files/
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Highlight
- Email to a Friend
Yes. I've read all articles you post in the pdoteam.com.
The valve is only one example. We still have some other situations like this.
- Highlight
- Email to a Friend
I think pretty much everything in the pcf can be controlled by the isoconfig, so I recommend exploring it. I'm pretty sure, the program just generates the data, rather than using a template to populate it. The isoconfig can change the pcf to the point that using a template isn't really practical.
Isaiah 57:15
ECAD, Inc.
- Highlight
- Email to a Friend
I don't think "template" is the right term for what you want. Are you looking for the PCF technical specifications, the ones that describe what each element of the PCF file is, what it must/may contain, and in what order?
Adopt. Adapt. Overcome. Or be overcome.
- Highlight
- Email to a Friend
Yes. You quite know me! One of our needs is to use the pcf file for stress analysis programs. Since there is no way to control the pcf format, we have to modify it handly every time.
- Highlight
- Email to a Friend
Yeah. I think you are right. Maybe the iso engine does that without any template.
- Highlight
- Email to a Friend
I don't think that information is publicly available/open format, like PDF (for example). It may be available for purchase through Alias for development purposes as part of licensing but I suspect the cost would be high. Thats one of my major complaints about the PCF format - not documented, only accessible (reliably, anyways) with Alias-provided and -licensed software.
