• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    dzine14u
    P3D 2013 - Where did my shortcut menus go?
    713 Views, 8 Replies
    09-07-2012 01:14 PM
    I finally got around to installing and setting up P3D 2013.  The only issue I seem to have is that the right-click shortcut menus do not seem to work at all. I have triple checked in Tools>Options that my settings are correct and are like they have always been yet the menus never appear. There must be another problem that I am not aware of.
    Is there a fix to get my right-click shortcut menus back? Please help.
    C. Altmix
    Engineering Designer
    Upper Consulting, Inc.
    www.upperconsulting.com
    Please use plain text.
    Product Support
    Venkatesan.A
    Re: P3D 2013 - Where did my shortcut menus go?
    09-10-2012 04:14 AM in reply to: dzine14u
    Can you try typing at the command window "shortcutmenu" and set the variable to "11"
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    dzine14u
    09-10-2012 05:44 AM in reply to: Venkatesan.A
    Thank you for your response but unfortunately it didn't work.
    C. Altmix
    Product Support
    Venkatesan.A
    09-12-2012 03:49 AM in reply to: dzine14u
    What actually happens when you right click? does it show any variable in the dynamic input?
    Try entering the variables 1 or 2
    http://docs.autodesk.com/PLNT3D/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4e99.htm
    guess we should check whether bit 1 (and maybe 2) of shortcutmenu is ON.
    Let me know.
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    dzine14u
    09-12-2012 06:59 AM in reply to: Venkatesan.A
    I have tried every possible variable setting yet there are no right-click shortcut menus that appear. When I select an object then right click, all it does is repeat the last issued command. So the shortcut context menus never appear no matter what the variable is set to.
    When I look at CUI all of the shortcut menu data exists. Note that the results are the same regardless of which set of workspace menus are loaded.
    I have attached a screenshot showing that the shortcut menus are turned on and the right-click customization settings. Thank you for your help.
    C. Altmix
    Active Contributor
    dzine14u
    09-17-2012 06:38 AM in reply to: dzine14u
    I still have no solution to this dillema.  I would really like to find a way to return my shortcut right-click context menus.
    C. Altmix
    Product Support
    Venkatesan.A
    09-17-2012 10:16 PM in reply to: dzine14u
    Have yout tried these ?
    http://forums.autodesk.com/t5/AutoCAD-2011/Right-click-Not-working/td-p/2919024
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Venkatesan.A
    09-17-2012 11:14 PM in reply to: Venkatesan.A
    I know you must have tried a lot of troubleshooting but just checking with you incase you have missed any of these.
    did you try this option type "PICKFIRST" at the command window and set the value to 1, or, goto TOOLS>OPTIONS>SELECTION and make sure the noun/verb box is checked.
    If this didnt work try the repair option, still didnt work I guess you will have to reinstall.
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    03-26-2013 02:13 PM in reply to: dzine14u
    The Noun Verb thing worked grreat for me.
