AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
P3D 2013 - Where did my shortcut menus go?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I finally got around to installing and setting up P3D 2013. The only issue I seem to have is that the right-click shortcut menus do not seem to work at all. I have triple checked in Tools>Options that my settings are correct and are like they have always been yet the menus never appear. There must be another problem that I am not aware of.
Is there a fix to get my right-click shortcut menus back? Please help.
Engineering Designer
Upper Consulting, Inc.
www.upperconsulting.com
Re: P3D 2013 - Where did my shortcut menus go?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you try typing at the command window "shortcutmenu" and set the variable to "11"
Venkatesan.A
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your response but unfortunately it didn't work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What actually happens when you right click? does it show any variable in the dynamic input?
Try entering the variables 1 or 2
http://docs.autodesk.com/PLNT3D/2011/ENU/filesACR/
guess we should check whether bit 1 (and maybe 2) of shortcutmenu is ON.
Let me know.
Venkatesan.A
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have tried every possible variable setting yet there are no right-click shortcut menus that appear. When I select an object then right click, all it does is repeat the last issued command. So the shortcut context menus never appear no matter what the variable is set to.
When I look at CUI all of the shortcut menu data exists. Note that the results are the same regardless of which set of workspace menus are loaded.
I have attached a screenshot showing that the shortcut menus are turned on and the right-click customization settings. Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I still have no solution to this dillema. I would really like to find a way to return my shortcut right-click context menus.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have yout tried these ?
http://forums.autodesk.com/t5/AutoCAD-2011/Right-c
Venkatesan.A
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know you must have tried a lot of troubleshooting but just checking with you incase you have missed any of these.
did you try this option type "PICKFIRST" at the command window and set the value to 1, or, goto TOOLS>OPTIONS>SELECTION and make sure the noun/verb box is checked.
If this didnt work try the repair option, still didnt work I guess you will have to reinstall.
Venkatesan.A
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The Noun Verb thing worked grreat for me.
