AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
P3D 2012 grid problem in Navisworks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Grid that is made in Plant 3D 2012 by cmd PlantSteelPlate is not showing up in Navisworks, can you tell me what could be the problem or a workaround. Object enabler is installed and other objects are OK.
Mechanical Project Manager
Petrokemija Co.
Croatia
Re: P3D 2012 grid problem in Navisworks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
c/p
Triangles, Lines and Points: 111265
Bounding Box: (-3,14685e-009,-58500,-300),(54630,8,0,34890)
16-31-STR-001-Struktura.dwg
Processed 7 LINE
Processed 4 SOLID3D
Processed 1 LWPLINE
Processed 251 GENPROXY
Processed 7 LAYER
Processed 112 GR_CIRCLE
Processed 765 GR_POLYLINE
Processed 88 GR_POLYGON
Processed 741 GR_SHELL
Processed 72 GR_TEXT2
Intresting in Navigator Palette you can see that everithing is OK (via Navisworks Navigator plugin in P3D)
Petrokemija Co.
Croatia
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This a problem in 2012, Insulation and grid no longer show in navisworks, when created with P3D 2012. It has been logged by Autodesk. See message below:
Chad,
You have to use NWCOUT to output to .nwd, which I see you have already tried. Currently, Navisworks will not display insulation on plant3d dwgs with insulation. We need to fix something on the Plant3D side.
Technically speaking, the insulation display variable is a sys var currently (only available in AutoCAD) and it needs to be changed to a per drawing setting (so that the setting moves with the drawing).
HTH.
Ratti.
Hope this helps clear this up. I think you should be able to use NWCOUT to output an nwd that will show the grid in Navisworks.
Chad
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
chad70811 wrote:This a problem in 2012, Insulation and grid no longer show in navisworks, when created with P3D 2012. It has been logged by Autodesk. See message below:
Chad,
Thank you very much, that solved the problem.
Davor
Petrokemija Co.
Croatia
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has this issue been corrected in Plant3d 2013?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This issue still has not been corrected in Plant3d 2013. Could someone from Autodesk please update us on when this problem will be corrected?
