AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: P3D 2012 ISOMETRICS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you Kyle, the snapshot helps.
Karthik is away for couple of days, hence jumping in. Engine does not scale up the fittings and components (it uses the scale specified by the user). The reason why control station (marked in yellow below) is not spaced-out is because there are no pipes that can be geometrically stretched. All the components are connected to the fittings, hence the result. I would like to discuss this more with you, will contact you separately.
-Murali
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
KP
Process and Power Specialist
ECAD, Inc
Our Blog
www.pdoteam.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I read your thread with interest - wish I had seen it before I spent many hours "playing" with the set-ups. Anyway I still have a couple of set-up issues that I hope somebody can help me with - see attached PDF file.
Thanks in advance
Regards
Gary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value there.
I'll see what I can find on the other problems and let you know.
KP
ECAD, Inc
Our Blog
www.pdoteam.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The problem with LDT info now showing on lines with multiple ISOs is a known problem with no solutions yet.
this post covered it:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P3D
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
on my last post, I ment "NOT" showing, not "NOW" showing... stupid edit function on this forum doesn't work
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your info - what prog do you use to open it up (I have founf the file) - could you clarify please - I think I am missing something somewhere
On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value -
Gary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I use a product called TotalEdit, it's a free download from www.codertools.com. You can also open the file up in notepad, but it has no formatting so it can be a little tricky to read.
KP
ECAD, Inc
Our Blog
www.pdoteam.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks that sorted out the hatch scaling a treat - I just need a few other answers on some other posts I did & Iwill be there on the Isos
Regards
Gary
